Hello! My fridge freezer has been making popping sounds for the past month. The fridge does not feel cold enough the setting is on 4 which I have on in the summer. The thermometer reading is 7 degrees.
Popping/gurgling ?,is there any frost build up in the freezer ?may be a loss of refrigerant which makes the refrigerant in the unit run noisier,would also point to the poor temps.
just had someone come in to have a look at the fridge. He said its was the module, the dial that controls the temp wasn’t working? does that make sense?? Is it worth fixing or shall I get a new fridge freezer?
