Bosch KGV-3104-G/04 Fridge Freezer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch KGV-3104-G/04 Fridge Freezer
Viewing 15 posts - 1 through 15 (of 19 total)
  • #7779
    BobHope
    The problem with this fridge freezer is either the module or thermister is faulty, bypassing the module with a direct conection to the compressor proves the compressor and system are OK. anyone got a wiring diagram or know what the thermisor reading should be and which wires lead to the little blighter. 😉
    Cheers Bob.
    #125142
    Dave_Conway
    Re: Bosch KGV-3104-G/04 Fridge Freezer
    Bob, read this thread from the public forum 😉
    http://www.ukwhitegoods.co.uk/modules.p … pic&t=2096
    #125143
    BobHope
    Cheers Dave,
    the module and connecter on this appliance only has three wires going to
    the module. Does this appliance have two thermistors to control both the fridge and freezer compartments, will have a go at the thermistors as i think the two screen or common connections may be joined internaly on the cabinate. would still like to see a wiring or mod diagram if anyone has
    one available.
    Thanks Dave.
    #125144
    Dave_Conway
    Looking at the picture on the Bosch site, it would appear to be one of the foamed in types as the thrermistors aren’t shown as spare parts.
    Sorry, I can’t help with the wiring etc as I’ve never actually done one myself, I’m sure someone will sort you out though Bob 😀
    On the same unit, we’ve just had one of these that’s had three boards in the last 18 months, all of them burn up. The customer has given up and bought a new unit but we are at a total loss as to the cause, no dampness anywhere near it, not outside :con:
    #125145
    BobHope
    Thanks again dave for the info,
    armed with my trusty multimeter i am sure one of the thermistors is O/Circuit, placed a 20k resistor across the plug on the module and the appliance burst into life. 😀
    i used to change the foamed in thermister on the candy products all the time, but i knew where it was located, would love to know the position of this little blighter and sort it out. but i will have to live with the mod i suppose. 🙄
    Cheers Bob.
    #125146
    sparkey
    Locate the three pin edge connector for sensors, the sensor wire connected to terminals 1 and 2 shoule be cut off about two inches from plug and joined together effectivly shorting out those terminals on the module. IMPORTANT do not disturb the other sensor wire which is also connected to terminal 1
    Regards
    Sparkey
    #125147
    BobHope
    Cheers for that Sparky,
    i had already sorted out that there must be two thermistors, any idea which thermistor is the offender the fridge or the freezer.
    thanks Bob.
    #125148
    sparkey
    Both sensors are in the fridge section, the one which fails is the evaporator sensor which tells the electronics when the evaporator has defrosted to end the defrost cycle, the other sensor is for the air temperature.
    When you short out the evap. sensor the control panel sets it’self into a timed defrost mode.
    There is no temperature control on the freezer side what so ever.
    Regards
    Sparkey
    #125149
    BobHope
    Thank you sparkey,
    most interesting, have you got a service manual by any chance.
    Cheers Bob.
    #125150
    sparkey
    No sorry, BSH do not do service manuals, whatever technical information is available is shown on their Quickfinder CD Rom programme, even thats out of date, have not received any updates since last year, they say it is now obsolete but have no replacement for it as yet??
    Regards
    Sparkey
    #125151
    Ray9500
    They have a new DVD version coming out anytime now 😀
    Ray
    #125152
    Dave_Conway
    Is there a part number for it please Ray ?
    #125153
    gegsy
    Ray9500 wrote:They have a new DVD version coming out anytime now 😀
    Ray
    Hi ray
    where did u hear that?
    we have to use tradeplaces since quickfinder ended; its ok but can be slow http://www.tradeplace.com/tradeplace/in … cale=en_uk
    Regards
    funkyboogy
    ( 3 wires coming from pcb )you can get a mod kit for this fault from bosch, but basicaly as mentioned u basicaly cut out one of the t/misters at pcb and this will cure fault>your best to get a mod kit from bosch cos u get a handy wee leaflet with it which explains mod ???…but once you get the leaflet u wont need to buy another mod kit..
    ps their is a mod for the 4 wire version …same as above cut out 1 t/mist…
    #125155
    sparkey
    funkyboogy wrote
    but basicaly as mentioned cut wire 2-3
    DON’T JUST CUT WIRES you must identify, cut AND JOIN wires together.
    See my post further up in this subject or look in subject ‘bosch kgv 2604 g in another posting in this forum for further information
    Regards
    Sparkey
