Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Bosch KGV Fridge Freezer Flashing Error Code E2
- This topic has 11 replies, 6 voices, and was last updated 21 years, 4 months ago by
JONTHETRUTH.
November 22, 2004 at 10:11 am #6876
JONTHETRUTH
ParticipantHi,
I have a Bosch KGV Fridge Freezer with a Flashing Error Code E2 on the Fridge temperature display (Freezer is ok). When the error first came up the Fridge was still running cold but now its not. Any ideas ?
November 22, 2004 at 10:20 am #120073Dave_Conway
ParticipantRe: Bosch KGV Fridge Freezer Flashing Error Code E2
Jon, can you please post the full model numer, it will be on the rating plate inside the fridge somewhere.
KGV????/GB??
November 22, 2004 at 10:37 am #120074JONTHETRUTH
The plate is not easy to read but I think its a KKV2901 GB01
Jon
November 22, 2004 at 11:14 am #120075Dave_Conway
Nope, that’s not it I’m afraid.
Either with the KGV or KKV prefix.
November 22, 2004 at 12:25 pm #120076JONTHETRUTH
Yep you’re right. It must be a KKU2901 then (rather than KKV), KKU is a recognised pre-fix, as well as KGU. Do you have anything on this model ?
Jon
November 22, 2004 at 4:17 pm #120077Dave_Conway
I’ve only a diagram and parts list for this model, which is correct BTW.
Hopefully someone may know what that error points to.
November 23, 2004 at 12:27 am #120078sparkey
E2 indicates failure or out of tolerence evaporator sensor which is foamed in and not replacable.
The only repair posibility is replacement of the electronic control board which now ignors input from the sensor. Repair costs in region of £146.00 inc vat. contact engineer in your area by using the ‘DIRECTORIES’ over on the left.Sparkey
November 23, 2004 at 9:15 am #120079JONTHETRUTH
Cheers Sparky
So the control board is also not repairable then, i.e. can’t disconnect the sensor link ? It has to be replaced ?
Jon
February 22, 2005 at 10:11 pm #120080admin
KeymasterRe: Bosch KGV Fridge Freezer Flashing Error Code E2
I’ve got the same problem E2 on the fridge of KK29U01GB (Siemens) – did anyone track this down. The fridge has now stopped working all together but freezer appears ok. Does it require a new board at c £150?
Cheers
RobFebruary 22, 2005 at 10:25 pm #120081Knights_Bridge
ParticipantAnonymous wrote:I’ve got the same problem E2 on the fridge of KK29U01GB (Siemens) – did anyone track this down. The fridge has now stopped working all together but freezer appears ok. Does it require a new board at c £150?
Cheers
RobI’ve just joined up so am no longer a guest
Cheers Rob (aka Knights_Bridge)February 22, 2005 at 11:36 pm #120082sparkey
See my post as above, same applies to Siemens and bosch fridge/freezers.
Electronic control board needs replacement 😥 check repairs@ on home page of this site for an independent engineer in your area
Regards
SparkeyFebruary 22, 2005 at 11:58 pm #120083gegsy
PCB for Bosch – KKU2901GB/01 and Siemens KK29U01GB is 263782 @ £96.00 GBP
Regards
