Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › bosch kgv2604g
- This topic has 12 replies, 4 voices, and was last updated 21 years, 2 months ago by
machineman.
January 25, 2005 at 6:32 pm #7634
machineman
Participantfridge freezer not working customer said int light on dim .would not switch of when door closed .any ideas before igo tommorow.m
January 25, 2005 at 8:21 pm #124355superfix
ParticipantRe: bosch kgv2604g
Sounds like ambient temp problem to me.
Light on dim is normal,if appliance is pcb controlled then it will come on automatically.If mech stat type then there is a s/w on the stat housing to turn summer/winter on or off.
January 25, 2005 at 8:43 pm #124356machineman
it is pcb cotrolled do they have trouble with these .m
January 25, 2005 at 8:50 pm #124357superfix
No not really.If it’s in a garage or some other kind of cold room then the light comes on half power to try and warm the ntc.
But if the room is too cold then motor wont run,hence stuff in freezer starts to defrost.
It will tell you at the start of the manual what ambient the appliance is suitable for.
January 25, 2005 at 8:55 pm #124358machineman
from what i gather its not in the garage and she has read about the ambient temp in the book, this has just stopped .m
January 25, 2005 at 9:05 pm #124359superfix
If you turn the power off and back on again does it run?.If so does it then stop completely again after a few hours?.
If so then it’s the foamed in sensor on the back wall,which is not replacable.However there is a by-pass kit available.
Hope this helps :tup:
January 25, 2005 at 9:08 pm #124360machineman
Participantno. told cust to turn m/c of for half hour then switch back on but still dead.m
January 25, 2005 at 9:12 pm #124361superfix
Well then it’s either ambient temp.pcb or motor.
Enjoy.
January 25, 2005 at 9:36 pm #124362machineman
Participantcheers boro will find out tommorow.m
January 25, 2005 at 10:06 pm #124363roly16
I’m not sure if leaving this off for half an hour is long enough to bring it back on. I had one of these in a basement that I thought was a low ambient problem but the mod bypassing the fridge thermistor cured it. I don’t recollect the interior light being on though. You don’t have to buy the mod kit; you can re-connect a couple of the wires behind the pcb using those blue insulated cable splice fittings but I can’t find my note of how to do it. I can prob find out though if you need to know.
January 25, 2005 at 11:29 pm #124364machineman
Participantthanks roly if you could find it i would be gratefull.m
January 25, 2005 at 11:40 pm #124365sparkey
Machineman,
First identify the sensor leads on the module, usually either a three pin or a four pin connector.
If four pin, locate the twin cable connected to terminal 1 & 3 cut off sensor cable about 2in from module and join together effectivly shorting out terminals 1 & 3 on the module connector.
If three pin locate sensor lead connected to terminals 1 & 2 and do as above. TAKE CARE to not disturb the other sensor lead which is also connected to terminal 1.
Terminal numbers are moulded into the white moulding of the connector plug.
Regards
SparkeyJanuary 26, 2005 at 8:14 am #124366machineman
Participantthanks sparkey.m
