Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Bosch KGV3120GB/01 Switching Problems
- This topic has 14 replies, 5 voices, and was last updated 19 years, 4 months ago by
Plastered.
November 22, 2006 at 11:01 pm #22802
Plastered
ParticipantThe Fridge/Freezer KGV3120GB/01 appears to swtich off at the correct point according to the settings, but doesn’t switch back on again. If I switch the power off and on again, it will spring back into life, but only when it has warmed up quite a bit.
I have checked the back of the unit and all seems free of frost or ice, and the grills are clean. The power is getting to the motor from the mains, but the supply is not being switched through to the motor when it should.
I don’t know where to access the thermostat, or thermistor, or whatever temperature sensing device it has, so have come to a halt with my investigations.
Could some knowledgable person give me some clues. You can talk technical if you like because I am an electronics engineer but do not know my way around a Bosch fridge/freezer. – Thanks.
November 23, 2006 at 7:44 am #196207Simon46
ParticipantRe: Bosch KGV3120GB/01 Switching Problems
A thermistor may have failed. A Modification will usually cure it. Check out repairs @ or unplug power if you are going to have a look yourself.
Regards
SimonNovember 23, 2006 at 8:04 pm #196208Plastered
Thanks for the reply.
There are no service engineers listed for my post code.Where is the thermistor located? Can I access it by unscrewing the 2 screws situated just above the top of the fridge door? I will definately switch off the power before going in.
The Bosch website gives an exploded view, but doesn’t go into enough detail. Also, I haven’t come across any thermistors when looking at Spare parts sites.
November 23, 2006 at 9:35 pm #196209pto
ParticipantPost removed by gegsy UKW Moderator
November 23, 2006 at 10:25 pm #196210superfix
pto wrote:…………..will have to cut the Foam away.
😕 Why do that, the by-pass kit takes all of ten minutes to fit and costs very little 😕
Try a search to find all the relevent info.
Again power off if having a go yourself :zap:
November 24, 2006 at 12:20 pm #196211pto
ParticipantThey do a kit but it’s just a expensive connector
And I don’t think the fridge will be as economic to run As when a thermistor is in circuit
But that’s just me thinking and it doesn’t always do
To thinkJack
November 25, 2006 at 9:35 am #196212Plastered
Going by the comments of pto (the ones I could read, because I don’t know what he said that made the moderator delete it!) I can either buy an expensive kit which basically adds another temperature controlled swtich, or dig into the foam to get to the original thermistor.
I think that both of these options leaves the unit in a worse state than the original condition, and in addition to the fact that I am going to have to work it out as I go along, I have decided to cut my losses and buy a new fridge/freezer.
Btw, did the moderator delete pto’s original message because he gave instructions on how to get to the thermistor? I can understand that there may be legal issues here if instructions are given, and someone gets electrocuted as a result, but it doesn’t help me trying to get information.
Oddly, I can only boot the unit back into life by using the mains switch on the wall, it doesn’t work using the on/off switch on the front panel, and only when the fridge compartment is virtually back at room temperature – why would that be?
On a more general note (minor rant coming up) what is the point of the manufacturers claiming to be all environmentally friendly by producing ‘A Rating’ machines etc, but in such a manner that if something simple fails you might have to throw it into the nearest landfill because you can’t easily change a 99p part. Ease of maintenance should be part of the specifications so the each unit can run for a few years longer which has to be a ‘green’ option – end of rant.
Thanks to those that tried to help.
November 25, 2006 at 10:59 am #196213Simon46
A Pity. This is a good fridge freezer and such a simple repair. 🙁
Regards
SimonNovember 25, 2006 at 12:41 pm #196214superfix
The repair is NOT expensive. A competent engineer will have the job done in under half an hour.
Seems mad to chuck the unit for such a minor/simple job.
November 25, 2006 at 12:54 pm #196215gegsy
Plastered wrote:Going by the comments of pto (the ones I could read, because I don’t know what he said that made the moderator delete it!)
Well if I repeated it that would defeat the deletion 😀 but basically it entailed hacking into a fridge insulation which seemed a tad excessive. If you can be bothered to use the search facility you may even find the mod has already been mentioned previously 😉
Its about £12 p/no 491416, so not too bad.
…. what is the point of the manufacturers claiming to be all environmentally friendly by producing ‘A Rating’ machines etc, but in such a manner that if something simple fails you might have to throw it into the nearest landfill because you can’t easily change a 99p part.
I agree to an extent but like I said and has been mentioned before, there are cheap alternatives to repairing 😀
HTH
November 25, 2006 at 6:17 pm #196216pto
ParticipantWell if I repeated it that would defeat the deletion but basically it entailed hacking into a fridge insulation which seemed a tad excessive. If you can be bothered to use the search facility you may even find the mod has already been mentioned previously
Not hacking into the insulation but to cut carefully a 2ins x 3ins
Hole and slip a new thermistor in placeIts about £12 p/no 491416, so not too bad.
What do you get for your £12 one connector that’s bad
I bet no one on here buys two kitsNovember 25, 2006 at 6:59 pm #196217pto
boro wrote:
😕 Why do that, the by-pass kit takes all of ten minutes to fit :zap:boro wrote:The repair is NOT expensive. A competent engineer will have the job done in under half an hour.
.10 mins 30 mins ?
November 25, 2006 at 7:00 pm #196218pto
.10 mins 30 mins ?
November 25, 2006 at 7:08 pm #196219superfix
As a BSH engineer it takes me 10 mins.
A non-Bosch or an engineer not familiar with the appliance may take longer.
Does that clear it up.
November 25, 2006 at 7:20 pm #196220gegsy
PTO
The options are there, either £12 for kit which is granted a mod sheet and two connector OR search for modification which has been posted on here before.
If you are comfortable cutting into the insulation of your own fridge then fine, however other people reading this may not be and may cause further damage to appliance or injure themselves. The main basis of advising on a repair is that it has to be deemed safe and acceptable to the public and we as professional repair engineers have to make sure that the repair offered is based on just that.
Hope thats the end of that as there really is no more to add on this post.Regards
