Bosch KGV32421GB/01 Fr/Fz
  • #66781
    maltheviking
    Anyone had one of these that is reluctant to switch on? The one I have only cycles on and off if its switched on/off at the mains. When it’s running it works fine until it gets cold, switches off and wont come back on. I feel its the PCB.
    Final question, are the NTC’s foamed in?
    Could aslo do with a service manual if anyone can help please. 🙂
    #365192
    Firestarter
    Re: Bosch KGV32421GB/01 Fr/Fz
    The faulty NTC is foamed in. I came across one last year. You can’t get to the one on the evaporator. Bosch didn’t do a repair kit at the time. They do list a Lining Repair Kit, but that just consists of sheets of sticky back plastic. Bosch replaced the fridge/freezer for the customer as the Appliance Care chappie said it could not be repaied.
    #365193
    Firestarter
    OR try this:-
    First identify the sensor leads on the module, usually either a three pin or a four pin connector.
    If four pin, locate the twin cable connected to terminal 1 & 3 cut off sensor cable about 2in from module and join together effectivly shorting out terminals 1 & 3 on the module connector.
    If three pin locate sensor lead connected to terminals 1 & 2 and do as above. TAKE CARE to not disturb the other sensor lead which is also connected to terminal 1.
    Terminal numbers are moulded into the white moulding of the connector plug.
    #365194
    maltheviking
    Already done at factory
