Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › bosch kgv33v60gb/01
- This topic has 7 replies, 3 voices, and was last updated 16 years, 5 months ago by
stu123.
November 9, 2009 at 12:55 pm #49996
stu123
ParticipantHi help on removing the evap cover in the freezer ?? thanks in advance
November 9, 2009 at 2:10 pm #302977superfix
ParticipantRe: bosch kgv33v60gb/01
Errrr there is no evaporator cover on KGV range 😕
Exposed evaporator, non frost free. Might be worth checking that E-Nr 😉
November 10, 2009 at 9:13 am #302978stu123
hmm i think i maybee caused confusion its the housing unit is in the top of the freezer where all the gubbings is hope that clears things up thanks 🙂 any help apreciated
November 10, 2009 at 7:34 pm #302979nomadPaul
ParticipantCould you mean a KGN rather than a KGV ?
If it is , it may need defrosting first .
Once defrosted , remove shelves and then two screws on rear panel . Take out rear panel.
Then remove two screws at top edge , holding in top evaporator cover . Once these screws are out the cover will slide forward….but only slide it forward approx 6 inches. Once it is in this position , you will need to reach behind it and unplug the defrost heater connection….i think its the 3rd one up of 4 . Once unplugged the whole cover will slide forward and out – Make sure the evaporator itself doesn’t come sliding out with it !!!
November 10, 2009 at 8:45 pm #302980stu123
thanks for that will go armed with the steamer cheers mate
November 10, 2009 at 11:19 pm #302981nomadPaul
ParticipantI take it that it is a KGN then ?
It would be much easier if you can get it defrosted 48hrs beforehand by getting it switched off.
If the evaporator is really iced over , the white evaporator cover is a bitch to get off as the evaporator is iced frozen to the defrost heater which , in turn , is frozen solid to the cover itself……and it is quite easy to damage the cover and/or heater.
Are you looking at fitting the mod to prevent the evaporator icing over ?November 11, 2009 at 4:57 pm #302982stu123
must get myself to specksavers dam these small model numbers . I was actually following up an engineer who is now on holiday he ordered a element and sensor .is the mod to keep the drain hole clear of ice ? or something else
and thanks agian for the adviceNovember 11, 2009 at 7:22 pm #302983nomadPaul
ParticipantThere is a mod where you fit a metal ‘sheet’ over the evaporator which apparently acts like a blanket to keep more heat around the evaporator during adefrost stage.
Is it an icing up problem with the evaporator ?
If the FD number is after 8701 it won’t need the drain hole heater mod.
We tend to fit a new PCB as well as the timings for the defrost cycle has been altered i believe.
