There is an E1 flashing on the display and the food is freezing in the fridge.
The freezer is also frosting up a lot. When I press the ‘cooler button it shows that the fridge is 4 degrees. When I press the ‘freezer’ button it shows the freezer is -18 degrees. However when I press the alarm button which shows the freezer’s warmest part it shows 4 degrees – which can’t be right.
There is nothing in the bosch manual that says anything about E1 message.
This is a new fridge – only 3 months old.
Please help. Thank you.
Re: Bosch KIS34A20IE/01 fridge/freezer – Fridge is freezing
E1 is a fridge sensor problem.
You will need to get a BSH engineer to sort for you as its still under guarantee. CALL 0844 8928979
For Ireland call 00 353 1450 2655
Lines in the UK are open Monday to Friday 8am to 8pm, Saturday 8am to 4pm and Sunday 9am to 3pm.
