After a 12 hour power cut the other day our Bosch KIV38X22GB/04 fridge light has been staying fully on when the door is closed and going fully off when the door is opened. Anyone had a clue whats going on here?
Yep, turned it off at the mains and am sure its on when the door is closed as the bulb is hot when you open the door, you can see the light on just as the door crack opens and you can manually press the door switch which makes it come on.
Very odd! Will try powering it down and back up a few more times.
