Bosch KSV2422GB/01 light switch
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch KSV2422GB/01 light switch
  • #15135
    Lawrence
    Got one of these with a jammed switch had a look on the BSH site and it shows a spring and clamping piece and what looks like some kind of
    actuator rod ,my question is what the ?and how do you remove it from the liner to fix ?
    regards
    Lawrence
    #162281
    superfix
    Re: Bosch KSV2422GB/01 light switch
    The cam can be teased out using a terminal driver, dont be too brutal though as it can snap :lesson: .
    you can then fish out the actuator (066888) probably find it’s bent, youcan then either bend it back into shape or replace, I usually just bend them and apply some silicone grease.
