Bosch KUR1505 fridge door seal wearing
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Bosch KUR1505 fridge door seal wearing
  • #27634
    Tamsino
    I have a Bosch KUR1505 integral fridge. The door isnt closing very well. You have to push hard to get the seal to shut together.
    If the seal is wearing out, is it possible to replace this? If yes, then where could I get a seal and could I do it myself? Or do I need to get a tradesman in?
    I dont believe the fridge is under warranty.
    #214940
    nomadPaul
    Re: Bosch KUR1505 fridge door seal wearing
    The seal would probably not be the problem . If its a built in fridge , with a front decor door , i’d be checking the hinges first . They can sometimes break and cause the door to drop. I’d also look to see if your fridge has ‘dropped’ back . If the fridge has been pushed back over time , the decor door might be hitting the cupboard that the fridge is installed in , thus stopping it from shutting properly.
    #214941
    Tamsino
    Ah, ok. Thanks. I will check this.
    #214942
    gegsy
    If you can supply full model number spares@ukwhitegoods.co.uk will be able to sort for you 😀
