Re: bosch leak
dopper wrote:anywhere these leak from?
The 10 most likely leaky areas are:-
1. Splashing over the top of the Pressure Chamber
2. Circulating Pump seals
3. Salt cap collar loose
4. Water Point under heater box
5. Tiny rusted holes in stainless tub usually under filter
6. Inlet hose connector dripping through rear hole in base
7. Customer opened door during hot cycle and steam shot down vent pipe onto base.
8. Bottom door seal kinked and not seated correctly (perished)
9. Mice chewed internal pipework
10. Heat Exchanger ‘O’ rings not seated properly.
Got to be one of those I reckon? 🙂
