Re: Bosch Loggix WIS24140GB/18
reaper wrote:Not obvious if and how the fascia comes off.
With the soap drawer out, remove the small plastic cover that is hiding the 2 screws holding the fascia on left of the dispenser cavity. (Its a push fit so no force reqd).
The fascia panel is also held on the right hand side by a plastic sprung loaded latch. Access via removing the lid (or if you don’t want to pull the beast out but can turn off the power first of course :wink:)Having unclipped the door seal from the front panel first, reach up on the inside to release said latch with your finger.
You can now remove the control panel complete and disconnect the plug-in connectors. That just leaves 3 screws holding the front panel at the top. BINGO, your in…..!!! 😀
