Bosch Logixx 1400 Express – Not Starting at all
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch Logixx 1400 Express – Not Starting at all
  • #14373
    kawan2
    The Bosch Logixx 1400 Express has a child-lock set on. Today, when we selected the programme and followed the usual instructions to start the washing, nothing happened. We thought the child lock setting must be faulty and decided to follow the instructions in the manual to turn it off permanently since our child is a bit older now ie. we reset to the factory standard settings. However, the washing machine still doesn’t start after pressing the start button.
    We have read through “Troubleshooting Minor faults” in the manual but cannot see anything there. Any ideas anyone?
    #159197
    Dave_Conway
    Re: Bosch Logixx 1400 Express – Not Starting at all
    Possibly a door lock problem, can you post the full model please from the rating plate; Enr……
    #159198
    kawan2
    Hi Dave,
    E-Nr. It is either WFR2867UK/01 or FR2867UK/01
    The reason being the “W” looks like / on the rating plate. That’s why I am not sure if the letter is either washed out or is not a letter at all.
    The production number is:
    FD 8304 700747
    BTW, I forgot to mention that when I press the Start button, there is a clicking noise after a while. Also, when I select 30 degrees Cotton programme, the light comes on somewhere else eg. 40 or 60 degrees.
    Thanks.
    #159199
    Dave_Conway
    WFR2867UK/01 is the model :tup:
    It may be an electronic problem then given the other syptoms you describe but still well worth a look at to be honest as it’s a good machine generally.
    Check the repairs@ link below for an independent engineer who should be able to help 😀
    #159200
    Martin114
    Motor Brushes ❓
    #159201
    kawan2
    Hi Martin114,
    I am not technically minded at all when it comes to washing machine. If the problem is Motor Brushes as you think, any indication of how much this part will cost and roughly the labour charges involved to fit this part. I am weighing up the cost of fixing against buying another washing machine (£399).
    Thanks.
    #159202
    Dave_Conway
    If it were motor brushes I would think (and it’s a very rough estimate) you would be looking at £60-£70 job done.
    #159203
    kawan2
    Thanks Dave for the info. I am hoping you and Martin are right about the part and cost beacuse my tumble dryer blew up this morning! 😡 There was smoke everywhere. No chance of fixing that.
    I am looking at buying the Whirlpool AWZ 3303 tumble dyer (£170). Any comments about the reliability of this machine.
    #159204
    Dave_Conway
    The Whirlpool is OK but look at Bosch as well 😉
    What make/model is your existing dryer, it may look worse than it is ?
    #159205
    don
    kawan2 wrote:I am looking at buying the Whirlpool AWZ 3303 tumble dyer (£170). Any comments about the reliability of this machine.
    Good choice of dryer kawan, A good workhorse and well built too. Good nationwide service back up as well. We use one of the earlier versions at home it gets good use and has given us good service.
    HTH
    Don
