bosch logixx 1400 fills/drains but not washes WFR2866GB
Home Forums Public Support Forums Help And Support Washing Machine Help Forum bosch logixx 1400 fills/drains but not washes WFR2866GB
  • #27125
    r1tch1e
    Hi, our bosch does’nt go into a wash cycle,it fills and drains ok though. A message saying “pump blocked” came up. I’ve cleaned the filter at the front, and the filters propeller? turns freely. Any guidance to where i should be looking now would be much appreciated. many thanks in advance.
    #212702
    nomadPaul
    Re: bosch logixx 1400 fills/drains but not washes WFR2866GB
    is the machine’s drain hose connected to a sink waste or just a free standing drain ? If its connected to the sink drain , i’d take the drain hose off there and check for a blockage/obstruction there next .
    #212703
    Simon46
    If filter has been emptied then drum should be empty. If Spin only selected does the drum turn?
    Regards
    Simon (wfr owner 😆 )
    #212704
    r1tch1e
    Thanks for your reply’s. having spent all day saturday removing and clearing blocked pipes right through to the waste (which is connected) the machine turned a few times then stopped again 😥 how you guys replace those clips again i dont know?? 😆 to date it fills and drains away although i dont know how it did before it was well blocked 😳 but still does’nt wash ie the drum wont turn on any programme.i can turn it by hand and the belt seems tight enough. the motor brushes were changed by an engineer last year by the way. any ideas to my next venture?? thank god for bank holidays 😆 thanks again
    #212705
    Investigate motor and brushes is your next step. They can stick in the holders.
    Power off, of course.
    r1tch1e
    thanks for your reply and i was worried you were going to suggest that 😳
    can i check/replace brushes insitu if not how does the motor come out as i have undone the two front long screw/bolts the back seems to sit in rubber grommit thingys, do i just leaver these off?? gently of course
    thankyou
    #212707
    Yup, got to come out. After the 2 long screws you will need to lever the motor towards the rear of the machine to overcome the hold of the rubber bushes.
