Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch Logixx 1400 Washing Machine not collecting softener
- This topic has 6 replies, 3 voices, and was last updated 19 years ago by
wakeypat.
April 12, 2007 at 1:18 pm #26539
wakeypat
ParticipantHi
I have a Bosch Logixx 1400 s Express washing machine that is only about 18 months old. After the wash cycle, the softener is still in its resevoir in the top drawer (eg hasn’t been washed into machine during the cycle). I have checked at the time it adds it, and although water runs through the two outer chambers it does NOT run into the centre (softener) chamber during ‘softener’ phase. Before I dive in and look, are there any well known problems in this area please?Thanks Pat
April 12, 2007 at 2:26 pm #210506Goatboy
ParticipantRe: Bosch Logixx 1400 Washing Machine not collecting softene
You could try a bottle-brush on the holes in the top of the soap-box. The little holes on the inside, where the water should come out.
Especially if your in a soft water area 🙂
April 12, 2007 at 3:52 pm #210507wakeypat
Thanks for the reply, I’ve already done that (it was a bit horrible in there, black guey stuff rather than limescale (we are not in a limescale area), however it doesn’t appear to have cured it. Wondering if I need to remove the whole dispenser box and give it a more thorough clean?
Thanks Pat
April 12, 2007 at 4:03 pm #210508Goatboy
There should be a finger-tip shaped dent, in the middle, toward the back of the drawer.
Push this down and pull the drawer to remove it 😀
April 12, 2007 at 4:25 pm #210509wakeypat
My fault, I wasn’t specific enough. I can remove the dispenser drawer OK. What I’m actaully considering is removing the control panel to allow access to remove the internal white moulding with the water feed holes in it. Then give it a thorough check and clean with it off the machine.
Thanks Pat
April 12, 2007 at 5:50 pm #210510Simon46
Poke small cable tie into ctre holes. Backed up with mould.
Regards
SimonApril 13, 2007 at 1:28 pm #210511wakeypat
Thanks Goatboy and Simon, you were right (of course), I used a narrow plastic tie wrap, followed by a jet of compressed air (from a can) to clear the Yukkie snot from the water feed holes and Whallaha, everthing is back to normal.
Thanks again
Pat
