Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch Logixx 7 Door Locked
- This topic has 8 replies, 3 voices, and was last updated 6 months, 2 weeks ago by
markyrp.
September 18, 2025 at 10:48 am #103567
markyrp
ParticipantHi,
My Bosch Logixx 7 washing machine door lock won’t release. I’m also unable to open the door manually via the emergency release. No error codes and washing machine appeared to working ok. I’ve tried unplugging, running the spin program a couple of times, etc. but it won’t unlock. There is resistance on the opening handle/lever. Any help would be greatly appreciated.
MarkSeptember 18, 2025 at 10:56 am #493736electrofix
Moderatormake sure your using the manual release properly. pull and hold release with one hand and open door with the other
also have you checked child lock is not engaged
September 18, 2025 at 11:12 am #493737markyrp
ParticipantHi Dave,
Thanks for your response. I have tried opening the door whilst pulling down on the manual release but unable to open.
With respect to a child lock, I don’t think there is one on this model.
MarkSeptember 18, 2025 at 11:27 am #493738markyrp
ParticipantAlso, probably should have mentioned that when you select a program or pause, you can hear an audible click from the lock mechanism.
September 18, 2025 at 1:14 pm #493739electrofix
Moderatordo you have the model no
normally inside the door but often repeated on the back seeing as you cant open it
will start Enr
September 18, 2025 at 2:04 pm #493740markyrp
ParticipantThe model number is WIS28440GB [h=1][/h]
September 18, 2025 at 9:16 pm #493741electrofix
Moderatorok all you can do now is try to get to the back of it and try to move the hook by hand
am thinking the door latch mech may be faulty. Hope its not as its complete door £200you can remove the front of the machine and it will come away and hang on the door rubber but give you enough room to get at the hook and push it
or you could just take lid off and see if there is any way to get it from the top
dont forget to unplug unless you want curly hair
September 18, 2025 at 11:08 pm #493742markyrp
ParticipantThanks Dave,
My gut feeling is that the door mechanism is the problem. If, as you say it is in the region of £200 for parts, it’s probably not really worth it for a machine that’s probably approaching 10 year old.
Thanks for your input though,
MarkSeptember 23, 2025 at 9:36 am #493743andyjawa
ParticipantMost likely just the handle at fault(?) as the plastic moulding breaks around the striker. Based on a WIS28440GB/06 version because you do not say.Well, by the line diagram of the door, the door handle and its striker is listed separately as part 00704287 BUT this is really a complete door at £197.98, outrageous. Hmm, somewhat confusing, if you were to look the complete door up as part 00704285 it is £205.46……Gulp! So if your flimsy door handle breaks this is how much it`ll cost you as a DIY. I phoned up Bosch to get clarification IN CASE OF A MISTAKE, there is no mistake and so the door handle you cannot buy as a separate part as the door is sealed apparantly.
This is a becoming a typical C21st Capitalistic ridiculous (and so caught by the short ones) rip off, a discusting state of affairs. And so the answer is: do not buy a Bosch as my honest opinion! OR if possible, you look and research how much the parts are listed BEFORE you buy one (recommended for any potential Miele owners too) and I cannot stress this point more whether a Bosch or any other make; the world is full of nasty surprises and this example is just another one of them. -
