Bosch logixx 7 WIS24140GB/20 -No Spin!
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch logixx 7 WIS24140GB/20 -No Spin!
  • #82060
    Adi156
    1st time post & appreciate any help please?
    My washing machine had flashing lights, suggesting a drainage blockage?
    I’ve replace a kinked drain hose and tested the drain pump. Both now resolved. The water was very dirty, with lots of slimey sediment. Also, I’ve checked the waste sump and dried out water from the base/float micro switch. Water enters the drum on any cycle & drains. But, that’s about it!! No spin still!!!
    Many thanks,
    Adi
    #418587
    Re: Bosch logixx 7 WIS24140GB/20 -No Spin!
    Check and clean out what may be a blocked air pressure chamber attached to the sump hose.
    #418588
    Adi156
    Re: Bosch logixx 7 WIS24140GB/20- No Spin!
    Hi Martin
    & thankas for your reply.
    Ive ordered motor brushes today, so Ill let you know how I get on?
    However, what does the pressure chamber look like? Do you mean the
    Adi
