Bosch Logixx 8 Condensing Dryer – WTS84509GB/16
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Bosch Logixx 8 Condensing Dryer – WTS84509GB/16
  • #92534
    pertheswede
    Our Bosch Condensing Dryer has recently developed a fault after the washing machine below it was replaced.
    The dryer turns on as per normal on any programme setting but then stops after a few minutes with the “empty water tank” symbol flashing even though it is already empty??
    It had been working fine for many years prior to lifting it off the old washer and then back onto the new one within just a few minutes.
    What should I be checking for or is there a “reset” proceedure I can try? (Like CTRL+ALT+DELETE on a computer?)
    Many thanks in advance!
    Regards
    Per
    #451528
    Re: Bosch Logixx 8 Condensing Dryer – WTS84509GB/16
    The pump and water level float may well be all crudded up. Side panel off and take unit out and clean it. No easy C/A& D solution I’m afraid so if unsure call out a local repairer and get it serviced.
    #451529
    pertheswede
    Repair man has now been booked in for this afternoon, thank you for your reply!
