Bosch Logixx 8 WAS32466GB/05 program select problem
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch Logixx 8 WAS32466GB/05 program select problem
  • #77445
    talkingtent
    I have a Bosch Logixx WAS32466GB05, the motor brushes were worn right down. Replaced brushes motor checked ok and bench run it. Trouble is now you can’t select any program no matter what buttons you press ?? If you turn the dial to cottons all you get is the 60 and 1200 on the display, turn the dial the other side you get 30 and 800 lights on the display ?? Can you reset the board or is it blown ? I’ve checked the two boards no signs of any blown tracks. Please can anyone help. Thanks James
    #402204
    nomadPaul
    Re: Bosch Logixx 8 WAS32466GB/05 program select problem
    It’s probably locked on F.21 – normally cleared by selector switch to 6 o’clock , press spin speed button , selector switch one click clockwise (7 o’clock position) release spin speed button . You’re now in test mode but just turn selector switch to off. Hopefully the next time you switch it to a cycle , it should be good to go .
