Bosch logixx dishwasher. Model SGS65L22GB/07 Pump Problem
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch logixx dishwasher. Model SGS65L22GB/07 Pump Problem
  • #82590
    PaddyW
    I have a Bosch logixx dishwasher. Model SGS65L22GB/07. it is not draining properly and is causing the program to stop. The detergent tablet was sitting on top of the dirty dishes when I open the door. I have checked the impeller for debris but it is clear. I blew down the drain hose and this pushed about a mug full of water back into the machine. It does not seem to be blocked. I need to test the pump but cannot see how to access it. Can you advise how I get access to the pump on this model. Thank you. PaddyW
    #420352
    Re: Bosch logixx dishwasher. Model SGS65L22GB/07 Pump Probl
    the pump is behind the impellor. these pumps do fail but normally they don’t start so all the water is left in. common fault is glass sticking the impellor which can be awkward to remove as you cant see them
