Re: bosch logixx not draining
one of the things you have to understand about these pumps is you cant bench test them. yes you can get them to revolve but having water inside them is a whole different ball game.
your buzz can be only 1 of 2 things the pump or the fill valves and in your case i would suspect the pump. these pumps get intermittant as they wear. look for side to side play in the impellor. when the play is too much the rotor jams and wont start sometimes
