Hi, my dishwasher gets stuck on the final drain cycle – the pump keeps running, though the water has drained fully.
This is an intermittent error – about 1 in 3 cycles it will drain and switch off as normal, for the other 2 it will drain and then indicate 1 minute left on the cycle, then continue to run the pump.
Wash seems OK, and the cycle of filling, dispensing detergent, heating, washing etc. seems fine. All intermediate drain cycles also work.
The problem may be related to improper filter fitting previously – I had to clean food debris out of the filters, arms and in the drain compartment. A month later, this issue has occured.
Any help, please?
Rajive
