Bosch Logixx SGS69A02 not finishing cycle
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch Logixx SGS69A02 not finishing cycle
  • #21354
    boghead
    THe original problem with the dishwasher was it was not washing very well and would occasionally count down to 1 minute remaining and sit there indefinitely. When it happened, it had not dried the dishes.
    Engineer came out and replaced both spray arms and put in a new control unit(PCB).
    It worked great for 6 days, dishes were very hot and dry at the end of the cycle.
    On the 7th day, it stuck at 1 minute remaining again and hadn’t got hot and dried the dishes. They come out wet and the water that is on them is chalky white.
    It now sticks at 1 minute etc every wash.
    All through what should be the drying period and afterwards when it is stuck at 1 minute remaining, it sounds like the pump is running. There is a gurgling noise and water is dribbling through the top arm.
    Does anyone have any suggestions? I am assuming it is a sensor as the PCB had been replaced but may not be.
    thanks,
    Robert
    #190548
    Re: Bosch Logixx SGS69A02 not finishing cycle
    Machine is probably underfilling and consequently not operating the heater. There is a corrugated hose in the front left corner under the machine which needs to be stripped out and cleaned to allow full filling.
    Power off if you wish to investigate this yourself, or click the link below for a UKW engineer in your area.
