Bosch Logixx SRS56A08GB
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch Logixx SRS56A08GB
  • #78112
    judderman
    Good evening all.
    Can anyone suggest what the problem is with this D/W
    The items on the bottom rack are not getting very clean, where as the top rack items come out clean?
    Both spray arm’s are clean as is the two mesh filters.
    I’m stumped 😕
    Thanks for any advice.
    #404488
    Re: Bosch Logixx SRS56A08GB
    The water point (diverter) device has failed. It forms part on the ‘instantaneous water heater’ and will need replacing in order to cure the fault. 🙁
    #404489
    judderman
    Martin wrote:The water point (diverter) device has failed. It forms part on the ‘instantaneous water heater’ and will need replacing in order to cure the fault. 🙁
    Thanks for the speedy reply Martin 😉
    That sound’s technical lol whereabouts is that located? Is it an easy-ish DIY job?
    Thanks.
    #404490
    judderman wrote:That sound’s technical lol whereabouts is that located? Is it an easy-ish DIY job?
    It is connected between the sump and the main circulation pump motor unit. And no it is far from a simple DIY job, costly too!:(
    #404491
    judderman
    Thanks again. 😉
    I just googled “bosch Dishwasher Diverter Valve” and read this on diynot.com
    Heater assembly has an alternator valve in it – this switches the water between the top and bottom rotors. It will have mechanically jammed or electrically failed. not a easy job, part is about 90.00 from bosch ,total strip down of dishwasher and i mean total door off wireloom off tub out the lot .i would save the money towards a new dishwasher .plus if you do it, it will need taking apart again cos of a water leak not good at sealing once they been apart
    http://www.diynot.com/forums/viewtopic.php?t=188960
    So the search begins for a new D/W. :rolls:
    #404492
    Well there you go, all credit to Google, you have unearthed all the facts. Glad to be of service. 😀
