Model number taken off the door, a clamped in machine 😈 and customer not at home so no book.
Bosch Logixx washer, 8kg, silver door and large black screen with orange display.
Programmes won’t select as normal. When you turn the dial from the off position, whatever programme shows when the display lights up that’s where it stays, you can’t scroll through programmes. The machine won’t start either, the start button just flashes.
Original fault description of no drain, but no water in the tub so I’m guessing that the fault occurred during a programme and it just didn’t finish.
No fault code showing 🙁
My feeling is that the board has had a wobbly but if anyone has any ideas on this one Monday could be a happier day 🙂
TC
