Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch Logixx WTL6508GB Pls help!!
- This topic has 7 replies, 3 voices, and was last updated 17 years, 5 months ago by
shaysmum.
November 10, 2008 at 5:48 pm #40922
shaysmum
ParticipantHi,
Am new to this forum, i have been browsing & really wanted some help on my condensing tumble dryer.
I bought the above, feb 2005 i barely use it, maybe only for 3/4 months in the year & only once a week at that!
Recently the cottons programs (esp cupboard dry) seem to stick! (comes on for 10 mins), then all the lights/beeping sound come on telling me to empty all the filters, which i have done lots of times to be sure!
I have been reading on the forum this seems to be a problem with other bosch dryers, any advice on what to do is greatly appreciated!
(Would it be any good to do a reset from the back?!)November 15, 2008 at 2:43 pm #268036gegsy
ParticipantRe: Bosch Logixx WTL6508GB Pls help!!
What lamps flash, not all surely πGreg
November 16, 2008 at 5:13 pm #268037shaysmum
gegsy wrote:Hi
Its the empty filter lamps π sorry i should have been more specific!
Its doing this now in all the programmes, only after 10mins into each programme. I read in the manual it could be condensing unit…any thoughts anyone?!November 16, 2008 at 6:08 pm #268038smartin
yes check condensor in bottom, it should be cleaned regulary, chances are if you havent done that then that is what it will be
November 16, 2008 at 6:28 pm #268039shaysmum
I checked & cleaned that before i posted here as specified by the manual, nothing has changed :(, just wondering what else it could be…….?!
November 16, 2008 at 6:33 pm #268040smartin
if everything is clean the only things it can be is if water isnt getting to tank at top(blockage or pump failure), or could be sensor
November 18, 2008 at 4:55 pm #268041shaysmum
Oh man! sounds really expensive, what should i be looking at re repairs?, d&G are offering a years warranty forΒ£89 π
Thanks in advance for any advice πDecember 29, 2008 at 3:43 pm #268042shaysmum
Ok so it is the sensor!, is there anyway this can be replaced without bankrupting myself?!, also got a friend who’s an electrician, can he replace it easily?, thanks in advance!
