Bosch Logixx7 washing machine
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch Logixx7 washing machine
Viewing 16 post (of 16 total)
  • #480375
    first you ned to check the motor
    the motor has
    armature 2 wires
    field coil 2 or 3 wires
    tacho 2 wires
    you need to check continuity of all 3. the armature and field have quite low resistance but the tacho is a bit higher
    then you need to check the tacho is generating voltage by setting meter on a low ac scale and spin the motor by hand while lead are connected to tacho output
    the fact the motor is doing nothing now means something has blown either in the motor or the circuit board
