Bosch Logixx8 fault code F27 Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch Logixx8 fault code F27 This topic has 10 replies, 4 voices, and was last updated 17 years, 6 months ago by viw2227. Viewing 11 posts - 1 through 11 (of 11 total) Author Posts September 13, 2008 at 7:14 pm #39466 viw2227Participant As title.Anyone know what it means ? or direct me to a site with the relevant info. TIA September 13, 2008 at 7:21 pm #262502 helo_75Participant a proper model number would help, and the gb/fd number on a sticker on the inside of the door September 13, 2008 at 7:34 pm #262503 viw2227Participant Re: Bosch Logixx8 fault code F27 😳 schoolboy error WAS 28466 GB Nothing seems to be wrong except for it showing code btw. September 13, 2008 at 7:43 pm #262504 helo_75Participant u sure its not f17? September 13, 2008 at 7:51 pm #262505 viw2227Participant F27 fo sho. Handbook list various ones and 27 is not on it. 17 being supply /filter issue.None of them tbh. September 13, 2008 at 7:58 pm #262506 viw2227Participant Re: Bosch Logixx8 fault code F27 Probably means faulty code reading 😆 September 13, 2008 at 8:44 pm #262507 gegsyParticipant Re: Bosch Logixx8 fault code F27 F27 Analogue pressure sensor error, check wiring to and from sensor and module. Power off if you are to have go :plug: Greg September 13, 2008 at 9:02 pm #262508 viw2227Participant Thanks Greg. September 13, 2008 at 9:04 pm #262509 helo_75Participant whatever you do, dont blow up the tube or the switch to test its function strange how its working fine September 14, 2008 at 8:25 am #262510 nomadPaulParticipant As its a WAS model , which is a relatively new model , it should still be under its 2 yr warranty . You should give BSH a call if it is less than 2 yrs since purchase September 14, 2008 at 1:49 pm #262511 viw2227Participant Yep, still under warranty but just wanted to know if it was an easy fix or sonmething more than that. Thanks all for the fast responses and keep up the good work. Author Posts Viewing 11 posts - 1 through 11 (of 11 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
