Bosch machine smelly!
  • #68287
    angel50
    For the first time ever I did a 90 degree service wash on my machine last week. The door seal has a bit of black mould on it & it smelt slightly mouldy.Ever since I did it though, it smells much worse- now of rotton egggs. I tried to drain it from the bottom- ususally loads of smelly water comes out, but this time hardly any water came out. Read the advice page on this hope & it doesn’t need a plumber. It seems to drain ok when i do a load of washing but the washing isn’t coming out smelling fresh even with my scented tablets. Any ideas? 🙁
    #370462
    Re: Bosch machine smelly!
    A common problem and this should help you:
    http://www.ukwhitegoods.co.uk/help/fix- … hines.html
    angel50
    Thanks, reading that then do you think my maintenenance wash disturbed the gunk? rather than a blockage in the drainage somewhere?& i should persevere with more mainttenance washes (with dishwasher cleaner maybe) until it improves.
    #370464
    Yup, that would be my take exactly. All you’ve likely done is take off the top layer of slime on the first pass or even a few, it can take a fair bit of effort to clear.
    angel50
    Thanks ok I’ll try that then! At least the load of washing I did in it today smelt a bit better than yesterdays! 🙂
