Bosch Max WFL2000 no spin
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch Max WFL2000 no spin
  • #74806
    bazofstour
    The subject machine does not spin on any cycle included spin only. Just makes grinding noise.Seems to drain ok though, and wash cycles ok. Also any ideas how to access the machine without completely dis-mantling, ie. which panels to remove,top removed ok.
    #392971
    Allsorts
    Re: Bosch Max WFL2000 no spin
    Possible that the motor brushes require changing
    #392972
    bazofstour
    would the motor brushes affect the wash process as well as spin?
    #392973
    Yes!
    #392974
    bazofstour
    Have ordered new brushes from your parts dept. Does motor need to come out to replace these. I have removed one brush from motor ok and it is worn. Also is the motor held in by two bolts only?
    #392975
    Yes and yes!
    #392976
    Allsorts
    Be very careful when removing and fitting the motor as the metal edges of the machine are very sharp
    #392977
    bazofstour
    many thanks for help and tips.will let you know when I’ve changed brushes next week!!
    #392978
    bazofstour
    Brushes changed, machine now fully functioning.Thanks again!
