Bosch Maxx 100 washing machine wash out failed
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch Maxx 100 washing machine wash out failed
  • #6614
    Bosch Maxx100 conditioner wash out failed?
    After the rinse cycle, the fabric conditioner remains in the tray. I have removed and cleaned the tray and there are no blockages. Therefore I reasoned the wash out from above is faulty. After unplugging! I tried to remove the top to check the mechanism, however removing the screws at the rear doesnt allow it to be removed. I have removed screws hiding the front panel but again it wont budge.
    Is there a technique for removing these panels? Are there problems with the wash out ie blocked valve etc. The washing powder gets washed in OK from the same tray.. I am a qualified electro mechanical engineer, however the old hidden fastenings beat me every time!
    The water in the area is hard and the machine is 3 years ol ❓ d.
    #118670
    Dave_Conway
    Re: Bosch Maxx 100 washing machine wash out failed
    Can you post the full model number Frank, something like WFL????/GB?? from inside the door on the rating label.
    I’ll have a look at the diagram for you.
    #118671
    Frank
    Hi Dave
    many thanks for the quick reply. The model number is WFL 100GB/ 12 FD 8205 600471
    Frank
    #118672
    Dave_Conway
    I replied to your email Frank. 😀
    #118673
    No need to take the lid off Frank!
    Just poke a ‘cable tie’ or similar thin tool through the holes in the top of the dispenser cavity adjacent to/and above the fabric conditioner compartment.
    They block up with bacteria build-up and doesn’t need too much effort to clear with the right tools 🙂 😉
    Frank
    Dear Dave – many thanks for the info, it makes life much easier whern you can see what you are dealing with.
    Dear Martin – thanks for the cable tie tip, it seems to have done the trick. Funny thing is I did scrub the outlet with a toothbrush earlier. I guess the blockage was before the outlet.
    Once again thanks, a very nice website!
    Frank
    #118675
    MalcolmWalker
    Bosch Maxx WFL 2000 washing machine
    I found this thread with search as I have a similar difficulty. But having throughly cleaned the dispenser tray (more than once) the conditioner is still not being dispensed. The outlet from the tray is clear and the funnel into the drum area and its outlet is also clean and clear.
    Is there another reason for the conditioner not being siphoned through and into the wash?
    #118676
    Simon46
    Can you see on the last rinse before the final spin into which compartment the water is going?
    #118677
    MalcolmWalker
    Ahh! Now I understand how it is supposed to work.
    But I have no idea at this moment which compartment the water goes into. So at the next wash I will check & reply further.
    Thank you for your response.
    #118678
    gegsy
    If you have low cold water pressure, the conditoner part will not work due to the design (2 valves operating and coming together at a point in dispenser thus operating conditioner unit)
    greg
    #118679
    MalcolmWalker
    I have thought for some time that the cold water pressure is less than it was at an earlier time. That is something for me check as well.
    #118680
    Hi Dave,
    any chance of emailing or posting any info for the same problem with a Bosch MAxx WFL2260.
    I’ve had almost every panel off the machine, but can’t see a way to get the plastic part with the holes in it (the part at the top where the water comes through) off without breaking it.
    Tried leverage with a small scewdriver but bits started to crack !
    Have been using a toothbrush for a couple of years now, but now this doesn’t seem to work anymore.
    This is obviously a common problem. Are Bosch aware ??
    #118681
    oh,
    I will try poking wire/cable tie through holes to see if this helps. Seems to have worked for others on here.
    cheers all.
