Bosch Maxx 5 (WAA24162GB/11) wont spin or drain the water
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch Maxx 5 (WAA24162GB/11) wont spin or drain the water
  • #55344
    bobbybarlow99
    Hello
    My Bosch Maxx 5 (WAA24162GB/11) wont spin or drain the water correctly there is still about half a litre of water left in the drum . There are two lights flashing the Rinse & Spin. Is there a way to reset the machine. Thanks. The machine is only 15 months old & had very little use.
    #323329
    Re: Bosch Maxx 5 (WAA24162GB/11) wont spin or drain the wa
    Has the machine got a pump filter that you can access down at the bottom right?
    All but the very basic, budget Bosch machines have one.
    If it has then you need to drain off the water, take out the pump filter and remove any obstruction or blockage you find.
    If there is no filter to access then the pump has to be unblocked from underneath.
    Be sure to remove the mains plug if you intend to do this.
    EDIT. Having looked at the parts diagram it looks as though your machine does have a user accessible filter behind the small round cover, bottom right.
    #323330
    bobbybarlow99
    Thanks for the reply, I have took the filter out & cleaned it. There did not appear to be any obdtructions
    #323331
    bosch-engineer
    If you have purchased your appliance brand new, it comes with a 2 year manufacturers warranty. Once you have checked the the drain pump as advised by iadom, you should make sure that you dont have a kinked drain hose or if it drains into the sink make sure the sink spigot is not choked up with fluff & grease deposits. Its not unusual to find small items like socks in the sump hose causing a restriction. When you checked the pump, did you try to turn the impeller with your finger? You should be able turn it & it should feel springy to turn, but not stuck. Sometimes a hair clip or something can be stuck behind the impeller causing it to become stuck. Once you are happy you have done all you can, then call Bosch service to arrange an engineer visit.
