Bosch Maxx 6 WAE 24190NL/03
  • #62015
    mike100
    Won’t let in water.
    There is water through stop cock and you can hear valve buzzing.
    This one is fitted with Aquastop hose. I disconnected the plug for this next to solenoid but there was still a buzzing.
    Is this likely to be the Aquastop or the solenoid valve
    Anyone had this problem.
    Mike 😕
    #348406
    nomadPaul
    Re: Bosch Maxx 6 WAE 24190NL/03
    Does it have an anti-flood protection system in the base ? Could there be water in the base pan ?
    #348407
    MDE
    Some Aquastops have 2 valves in them, if one is gone you will here a buzzing sound but it will not fill.
    #348408
    mike100
    Tried another Aquastop hose, still the same.
    Fitted ordinary inlet hose now works fine.
    When I tested there was no power to Aquastop plug so maybe there is a fault coming out of the board.
    Anyway thanks for your answers.
    Mike
