It worked fine to recently and then just stopped as follows:
Start my normal cycle, the timer comes on, the click engages, the water goes in from the cold, and then it….. Sits there.
The timer continues to gp dpwm, but drum doesn’t turn and at end the water is still in the drum. I can use drain option to get the water out, and I can then open the door.
90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure to be the motor brushes worn. you will need to remove the motor to check the lenght left on the brushes –
