Bosch Maxx WAB24060GB05 – Not heating the water
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch Maxx WAB24060GB05 – Not heating the water
  • #101640
    n8mfafie
    Need help please, trying to diagnose if the PCB is faulty on our old bosch washer and it’s worth a punt and the £££ to replace it. Been looking in to saving energy around the house when we realised the washer wasn’t using anything like we expect and confirmed waste water and drum are cold after a 90 degree wash which might explain why the seal had gone very mouldy recently.
    So far I’ve replaced the door seal and element (think the old one was actually ok) and checked continuity on the loom between the PCB and element, pressure switch seems ok – it’s closing the contacts after filling for a while and blowing down the tube both ways is free.
    Stripped the controller down and there are signs of overheating on the board, sooty deposits. There was a burnt track / dry joint around the relay which I’ve repaired but still no joy.
    Still need to check the temp sensor and voltage at the terminals (bit tricky with the drum whizzing round)
    Anything else I can check or am I throwing more money away?
    #485512
    check the heater relay
    andyjawa
    Looks like solder is also naff to me?
