bosch maxx WFL2050
  • #47419
    mackos
    HI guys got a bosch wfl 2050 can’t seem to reset it.If I turn it to off then on to a prog spin or drain it only pumps out if I put it to a wash prog it pumps out & I get wash action.I can flick it between active & ready but it makes no difference it still does the same & will not finish.any thoughts.Thanks Mack.
    #293405
    Re: bosch maxx WFL2050
    Sounds like a pressure switch problem to me.
    mackos
    thanks Chris I did have a look at the vipler hose & pressurestat if I remember right it did seem to have only one level should it be a two level switch.thanks Mack.
    #293407
    Single level plus flood protection – extra terminal will run the drain pump, so might be stuck?
    mackos
    thanks I will have a look tomorrow if I get a chance.Mack
    #293409
    mackos
    Hi Chris I went back & checked the pressure switch that’s fine.Any other suggestions.Thanks Mack.
