This machine makes a horrible noise and does not pump out. Pump cavity and filters are all clear. Machine stops with END light flashing. Any Ideas? Anyone know how to get at the Pump body?
In my case the outlet pipe was blocked with gunk. Had to remove pipe and flush through in kitchen sink. Weighed a lot less after that and went back more easily than it came out. The difficulty is detaching the spring clip sufficiently to pull the pipe off the pump. I detached the main pipe from the drum to the pump at the pump end to improve accessibility. Putting back, all the clips now face the correct way for easy access. The work has to be approached initially from underneath but the upper retaining clips to the back plate are best accessed from above.
