Bosch Maxx WFL2260 – Poor quality wash
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch Maxx WFL2260 – Poor quality wash
  • #54934
    nelson
    I am stumped with this one chaps, customer complained that the clothes were just not coming out clean, ie deodorant marks still left on white shirts washed at 60 deg.
    I checked which detergent they were using, and they’re using Ariel powder, should be ok I thought.
    Been out to the machine and checked the heater, ntc pressure system all ok. Then I ran the machine to check that it was agitating ok, it was and got up to temperature.
    So I am stuck, I can’t think what else to look for that would affect the wash quality.
    Any ideas 😕
    Cheers
    #321428
    Re: Bosch Maxx WFL2260 – Poor quality wash
    nelson wrote:Any ideas 😕
    By far the most common cause of these symptoms is sludged-up drain hoses and gunged-up pump inlet from the sump hose. Or even clogged-up ball valve in the sump hose? Constant ‘quick wash’ programmes and 40deg progs all the time take there toll and on a WFL2260GB/01.
    Taking the drain hose off to flush clean is a pain. So instead I use a drain clearing compressed air gun. (Brilliant they are!). Remove the pump filter and cover the vacant hole with a damp towel. Take the end of the hooked drain hose and pour a little water (about a pint) into the hose. Pump up the air gun 15-20 times then BLAST-IT CLEAR!!! (Make sure that towel can hold back the shoosh ‘cos it can be real messy what comes out.:wink:
    Do that a couple of times and the entire hose will be super clear!!
    HTH? 😀
    #321429
    pmb
    Ask them to show you how much powder or Liquid they use.
    In hardwater London,90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of poor wash faults Are user faults, Overloading or not using enough Powder/liquid.
    If they use powder they rarely use measured amount
    I recommend tablets.
    Load=3/4 full dry washing. When it fills and tumbles, Should be half way up glass when stationery.
    If necessary put wash on before you leave, phone later to check OK
    #321430
    Turbo
    Sounds like they are over loading to me.
    Graham
    #321431
    happycack
    Insufficient rinse or overload sounds favorite. Has this problem just started and machine o.k. before ? If it was good then what is she doing different now?
    #321432
    nelson
    I have advised the customer that there is nothing wrong with their machine and to try different detergents ie tablets with a fixed dosage. I also warned that overloading the washer will cause it to not wash properly.
    Thanks for your input everyone. 😀
