Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch Maxx WFO 2860
- This topic has 11 replies, 4 voices, and was last updated 20 years, 5 months ago by
charlieT.
November 6, 2005 at 7:46 pm #13110
charlieT
ParticipantMy machine is 3 years old and has recently got stuck on the wash cycle. It has a timer countdown which goes down to zero but continues to wash.
I need to switch to rinse manually. I notice that the spin is not as quick as it used to be. Any ideas out there? NB I have checked that all the pipes are clean etc.November 6, 2005 at 8:36 pm #153208Dave_Conway
ParticipantRe: Bosch Maxx WFO 2860
When you checked the pipes, did you also check the filter ?
November 6, 2005 at 8:46 pm #153209charlieT
Thanks, no, where does that hide?
November 6, 2005 at 8:55 pm #153210Dave_Conway
Bottom right, there’s an inspection cover that reveals it.
Have a towel or two at the ready 😉
November 6, 2005 at 9:42 pm #153211charlieT
Thanks Dave but only thing bottom right on mine is the pump?
November 6, 2005 at 9:49 pm #153212Penguin45
The filter is on the front of the pump.
November 7, 2005 at 6:48 am #153213charlieT
Thanks the pump is clear and OK. What next?
November 7, 2005 at 8:30 am #153214Martin
charlieT wrote:Thanks the pump is clear and OK. What next?
Take a real close look at that pump I would….3yrs use is the best you can expect out of a pump and I bet the impellor is loose and wobbles side to side????….new pump time! 😉
November 7, 2005 at 5:48 pm #153215charlieT
Thanks, the pump is fine. no wobbles. Pump is more or less empty when I open it. Why would that mess up the cycle?
November 8, 2005 at 5:25 pm #153216charlieT
So if it’s not the pump what might it be? 😕
November 8, 2005 at 5:33 pm #153217Martin
charlieT wrote:So if it’s not the pump what might it be? 😕
Partial blockage in the hose from that pump to the drain. (Tip: If the machine does not empty on the ‘Rinse only cycle’ within 60-90 seconds then that’s the problem)
Solution: remove the drain hose completely and rod/flush it clear!!!!
A day in the life of a service engineer can be avoided if you get someone in to sort it for you…please try :
Repairs@November 8, 2005 at 5:54 pm #153218charlieT
I’ve had all the pipes out and they are cleaner than the average pipe in a pub.
What next Doc? -
