Bosch MBS533BS0B double built in oven installation
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Bosch MBS533BS0B double built in oven installation
  • #94369
    digital
    I have a Bosch MBS533BS0B to install but there are a couple of brown plastic blocks on each side. Their mid points are level with the bottom of the top door and top of the bottom door and they are situated behind the front panel which means, as far as I can see, that they will stop the oven from sliding fully into the cupboard housing. Before I lift it into place (it’s heavy!), do I need to remove them and, if so, how?.
    #457137
    Re: Bosch MBS533BS0B double built in oven installation
    did you look in fitting instructions ?
    it says bin it
    digital
    Thanks. I did, and the installation sheet I have here is different from the one you have. There’s nothing in any of the literature that came with the oven which refers to the blocks. They’re in the bin now!
    #457139
    that’s mad,went to bosch and downloaded fitting instruction for your model of oven
    anyway its nice when a solution is so simple
    don’t forget to register you appliance. Its important in case safety issues arise in the future
