Bosch microwave.
  • #100812
    clockworkone
    I dont generally touch microwaves but this is my own integrated one. Model no is HMT85M650B/02. Checked 10a fuse and it was gone. replaced and blew on start. tripped mcb and not rcd. Any ideas.
    #482285
    find the inverter
    item 420
    https://www.bosch-home.co.uk/supportdetail/product/HMT85M650B/02#/Tabs=section-spareparts/
    disconnect the 2 supply wires to the inverter
    go armed with smaller fuses. i use 6.3A just to test
    the 2 things that can blow fuses are
    1 door switches
    2 failed inverter
    if you disconnect the 2 pin mains plug to the inverter then it shoulld turn on and start with no problems. the programme will abort as soon as it cant see the inverter but if it does all this with no fuses going you need a new inverter plus maybe a new Mag. All of which is cheaper to source as panasonic parts
    clockworkone
    Many thanks for good advice.
