bubs wrote:Where is the spell-check on the subject line?? 😳
Sorted 😉
E8 is problem with the inverter board not activating.
I would remove the magnatron and check that the permamagnet isn’t cracked and also its resistence failing that its most probably the inverter board itself 😀
Make sure that the installation ventilation is as per tech sheet as they need more than a usual single oven 😉
