bosch microwave hbc86q651b/01
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries bosch microwave hbc86q651b/01
  • #68877
    adv
    turntable not goin round weird this , take plate off an can see coupling turning , put plate on wont turn , is it more likely to be turntable motor ,?the metal turntable plate aint that heavy realy , coupling drivelooks ok any clues lads ?
    #373052
    Hollytree_Technical
    Re: bosch microwave hbc86q651b/01
    If the correct voltage is getting to the motor then I would suggest that the motor is burning out and not able to provide the torque required any more.
    Jem
    #373053
    adv
    ok ta
    #373054
    franz
    Have had quite a few Panasonics doing the same thing – turns out to be the spider – must be worn where it meets coupling on motor . Dont know if Bosch use a similar spider or not.
    Franz
    #373055
    adv
    Do you mean the coupling that plate runs on ? That pushes on end of motor ?
    #373056
    franz
    Yes – seems to turn ok when nothing on it but if you put a plate or micro meal it wont turn
    Franz
    #373057
    adv
    ok ta
