Bosch Microwave Oven HBC84E653B turning off 24 seconds
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Bosch Microwave Oven HBC84E653B turning off 24 seconds
  • #93387
    IWANTBLUE
    Bosch Microwave Oven HBC84E653B TURNING OFF AFTER 24 OR 36 SECONDS ON TOP 3 POWER SETTINGS BUT NOT ON 90 AND 180 SETTING.
    So as this microwave turns itself off after exactly 24 seconds or 36 seconds when on power setting 900/ 600/350?/
    but will complete the cycle on the 180/ and 90 power levels(defrost etc…
    any ideas please guys??
    I can hear the double click for the door switches and opening the door cuts out the fan etc as you would expect? so appears to me to be operational as far as can be ascertained without stripping out (built in microwave combination oven/grill etc…
    The other heating functions work as normal, it is the Microwave only that has an issue??
    initially, when (mum) tried it she repeated the turning on cycle numerous time and eventually it came on and worked normally, however now it has stopped completely πŸ™
    does anyone have any clues as to the possible problem with the microwave, please?? despite the lower power settings going through the motions, I don’t actually think the microwave is working at all, but only the top 3 power settings turn off after 24 or 36 seconds EVERY TIME πŸ™
    I would have expected a non-working microwave to show as an error code rather than this repeated 24/36 seconds thing :/
    Thanks in anticipation .. Whilst not a specific whitegoods/oven repair man I am an electro-mechanical engineer so not a complete ‘layman’ and am well aware of the dangers involved with a microwave
    Thanks in anticipation πŸ™‚
    Nick
    #454192
    Re: Bosch Microwave Oven HBC84E653B turning off 24 seconds
    this unit based on a Panasonic unit. The control unit detects if the microwave is running or not. If its not it just stops
    you will need a professional to sort this. There are very high dangerous voltages involved ( 5000v DC)
    there are 2 components involved either one or both may be faulty. The good news is you can use Panasonic parts and avoid Bosch prices
    IWANTBLUE
    thanks Dave, I suspected as much πŸ™
    I was a touch bemused by the exactly 24 or 36 seconds though , so hoped it might be a pointer of some sort… I was also surprised this ‘state’ wasn’t covered by an error code as well as its not exactly complicated is it LOL :- No microwave detected Flag Error5,
    Error5 = No microwave detected, call engineer do not use etc…
    whilst I couldnt get it to work it had worked at random times the day before , Ho hum..
    do these items have a fair use policy with regard to warranty? it is a few years old but surely a 4/5/Β£600 combination oven shouldn’t go faulty for much more than a year or whatever…
    Thanks again anyway ..
    Nick
    #454194
    IWANTBLUE
    along the line of my previous post Dave I had wondered whether the 24 seconds and or the 36 seconds cut out were indeed a code in themselves, as it seems too obvious to not be ( from an engineers viewpoint) so is there a Bosch or if as you suggest panasonic ? code refference table anywhere?
    like
    0-10 seconds = fan fault,
    11-20 = main board fault
    21-30seconds = Magnetron fault
    31-40 seconds = Relay board fault
    ETC?? as I’m sure ive come across such troubleshooting aides before..
    Cheers, Nick
    #454195
    In this case no. There are error codes for other faults such as temp sense failure and the like.
    In your case you say it worked on and off so of the 2 components that may be causing it I think only 1 may have gone and it’s the cheaper one
    The part you need is over Β£100 from Bosch but should be able to be supplied for about Β£80 plus fitting (hopefully)
