Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch Microwave Oven turntable runs when not in use.
- This topic has 7 replies, 4 voices, and was last updated 15 years, 11 months ago by
Twoten.
April 29, 2010 at 9:52 am #54283
Twoten
ParticipantBosch HBC86Q650B/02 Combi oven.
When the door is closed the turntable motor buzzes and turns very slowly. When the microwave oven is started the turntable motor does not rotate.
All the door switches operate correctly.
I have found an earth fault of 3 Megohms in the oven element. I have isolated the faulty element and the fault still exists.
I can’t think of anything else likely to cause this fault therefore by a process of elimination think it likely to be the power board.
Has anyone any other input to this problem?
April 29, 2010 at 4:18 pm #319062SWERV
ParticipantRe: Bosch Microwave Oven turntable runs when not in use.
Is the light working? had a couple where the lamp has blown and blown tracks etc on the board, which can give this fault.
MervApril 29, 2010 at 5:56 pm #319063Twoten
The bulb still works on his oven.
Was it the power PCB that blew?
April 29, 2010 at 8:26 pm #319064nomadPaul
ParticipantOf the 3 or 4 times i’ve seen this fault its always been one of the door switches faulty although its only on standard microwaves that its occurred .
April 29, 2010 at 9:33 pm #319065Twoten
ParticipantnomadPaul wrote:Of the 3 or 4 times i’ve seen this fault its always been one of the door switches faulty although its only on standard microwaves that its occurred .
I’ve found the same in the past and assumed this was going to be an easy repair!
This machine has a simple switching mechanism and works OK.
April 30, 2010 at 8:00 am #319066SWERV
Yes it was the power board that blew.
MervApril 30, 2010 at 4:38 pm #319067SimonCD
I have had the same fault, the actuator that opens vent cover had shorted blowing a few tracks on main pcb. expensive!
April 30, 2010 at 9:12 pm #319068Twoten
As the machine required an element as well as the main PCB the customer has decided to replace rather than repair.
Thanks for the feedback.
Keith.
