Bosch Model No SGS5358GB/17
  • #16813
    funkyboogy
    not been to yet..wont fill… pump runs,occording to customer
    any ideas ???
    cheers funky
    #171683
    bendaireboy
    Re: Bosch Model No SGS5358GB/17
    sound’s like water leak into base activating float causing drain pump to run,i’d look at pumps for leakage hope this helps regard’s nige 🙂
    #171684
    gegsy
    If no water in base, I would suspect module. When you look at 7 seg display when you go; if there is a red dot in the display then definite module.
    Remove l/h panel check pressure chamber for crud, also remove lower front and remove 1foot length ribbed hose and clean.
    Regards
    funkyboogy
    UPDATE ON JOB
    went out took lhs panel as suggested….removed all the hoses and cleaned…also removed little flap valve thingy in sump…gave it a clean , put all back together….and happy days….thanks for advice
    funky..
    #171686
    BSH-MAN
    funkyboogy wrote:UPDATE ON JOB
    funky..
    You’ll go back!
    :clown:
    #171687
    funkyboogy
    Miby aye and Miby naw….
    but i do have a sneaking feeling a might be…
    #171688
    gegsy
    So whats the answer BSH MAN? Replace metering unit and ribbed hose and if really gunged the water matrix??
    superfix
    Think he may be thinking flooded base problem Greg. However if it was just gunged up sump hose then cleaning will do the job, for a couple of years at least.
    #171690
    gegsy
    Hya Boro, thanks for that; was just wondering what more we could offer for a more reliable repair 😉 .
    Cheers
