Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch Module 264877
- This topic has 15 replies, 5 voices, and was last updated 18 years, 4 months ago by
mjhservices.
December 8, 2007 at 12:06 pm #32840
mjhservices
ParticipantBosch Module 264877
Fitted one yesterday and was alright until I pressed the two buttons to reset it and it went to zero and pumped out, but then it got stuck on zero with the last programme light displayed and was doing nothing.
Tried resetting and turning off for a couple of minutes but stayed stuck displaying zero, even unplugged module completley but no change.
Had another module in van that I then fitted and the same thing happened all over again (exactly)
Can anyone help?Mark
December 8, 2007 at 12:10 pm #236587gegsy
ParticipantRe: Bosch Module 264877
Can you supply model of appliance and I will be able to aid you further 😀Greg
December 10, 2007 at 7:44 am #236588mjhservices
The model is Siemens SE23260GB/12
Regards Mark
December 10, 2007 at 9:15 am #236589gegsy
Hi Mark
Re check that model number would you 😉Greg
December 10, 2007 at 1:06 pm #236590mjhservices
Yes thanks the correct model
Mark
December 10, 2007 at 3:04 pm #236591Martin
mjhservices wrote:The model is Siemens SE23260GB/12
I’m willing to bet that it isn’t Mark? 😉
My money’s on it being an SE26230GB/12 8)
December 10, 2007 at 3:41 pm #236592mjhservices
Maybe I got that a bit wrong?
Can you help anyway?
MarkDecember 10, 2007 at 5:17 pm #236593Martin
mjhservices wrote:Can you help anyway?
I’ll at least try Mark….. 😉
I think you can rule out the module for a start in that 2 new modules can’t both be faulty? 😕
I guess you are saying it won’t start on any programme? Because you have confused me over the ‘reset’ issue? In as much as when you reset the machine it should pump for 60secs then switch off, but then the display will always show ‘0’ and one of the prog buttons will stay illuminated as far as I recall on these machines?
So, tell me, have you checked the machine throughout to see if all it’s components are OK (Heater, Pressure System etc etc) prior to sticking in new modules?
December 10, 2007 at 7:12 pm #236594gegsy
Did you code the module as per encolsed sheet?
December 11, 2007 at 7:38 am #236595mjhservices
You do not code this module
December 11, 2007 at 1:01 pm #236596superfix
mjhservices wrote:You do not code this module
Oh yes you do, some of them have a coding plug fitted to the original PCB. IIRC it sits on the rhs of the board.
If there was one fitted it MUST be fitted to the new one too.
I hope you aint binned the original :rolls:
December 11, 2007 at 4:33 pm #236597mjhservices
No there was no coding plug on the original as I still have it.
Mark
September 24, 2008 at 1:16 pm #236598timdowning
Got to change one of these on a SGI5302gb/07 7901110097.
Need clarification please:
I haven’t got a coding plug on my old module so that bits fine.
Do I have to carry out wiring change as per Commutation instruction on this model???
Is there programming to be done on this module as I haven’t got any other paperwork in with the module.
Cheers.
September 24, 2008 at 1:46 pm #236599Martin
timdowning wrote:Is there programming to be done on this module as I haven’t got any other paperwork in with the module.
No programming required as far as I’m aware, just a one for one swap. But you’ll need to configure the salt setting once its installed. (IIRC is defaults to setting 0 – I think? 😕 )
September 24, 2008 at 1:49 pm #236600timdowning
Cheers Martin.
Did want to goose the new board. 😉
How about this bit;
Cheers
