Bosch Module 264877
  • #32840
    mjhservices
    Bosch Module 264877
    Fitted one yesterday and was alright until I pressed the two buttons to reset it and it went to zero and pumped out, but then it got stuck on zero with the last programme light displayed and was doing nothing.
    Tried resetting and turning off for a couple of minutes but stayed stuck displaying zero, even unplugged module completley but no change.
    Had another module in van that I then fitted and the same thing happened all over again (exactly)
    Can anyone help?
    Mark
    #236587
    gegsy
    Re: Bosch Module 264877
    Can you supply model of appliance and I will be able to aid you further 😀
    mjhservices
    The model is Siemens SE23260GB/12
    Regards Mark
    #236589
    gegsy
    Hi Mark
    Re check that model number would you 😉
    mjhservices
    Yes thanks the correct model
    Mark
    #236591
    mjhservices wrote:The model is Siemens SE23260GB/12
    I’m willing to bet that it isn’t Mark? 😉
    My money’s on it being an SE26230GB/12 8)
    #236592
    mjhservices
    Maybe I got that a bit wrong?
    Can you help anyway?
    Mark
    #236593
    mjhservices wrote:Can you help anyway?
    I’ll at least try Mark….. 😉
    I think you can rule out the module for a start in that 2 new modules can’t both be faulty? 😕
    I guess you are saying it won’t start on any programme? Because you have confused me over the ‘reset’ issue? In as much as when you reset the machine it should pump for 60secs then switch off, but then the display will always show ‘0’ and one of the prog buttons will stay illuminated as far as I recall on these machines?
    So, tell me, have you checked the machine throughout to see if all it’s components are OK (Heater, Pressure System etc etc) prior to sticking in new modules?
    #236594
    gegsy
    Did you code the module as per encolsed sheet?
    mjhservices
    You do not code this module
    #236596
    superfix
    mjhservices wrote:You do not code this module
    Oh yes you do, some of them have a coding plug fitted to the original PCB. IIRC it sits on the rhs of the board.
    If there was one fitted it MUST be fitted to the new one too.
    I hope you aint binned the original :rolls:
    #236597
    mjhservices
    No there was no coding plug on the original as I still have it.
    Mark
    #236598
    timdowning
    Got to change one of these on a SGI5302gb/07 7901110097.
    Need clarification please:
    I haven’t got a coding plug on my old module so that bits fine.
    Do I have to carry out wiring change as per Commutation instruction on this model???
    Is there programming to be done on this module as I haven’t got any other paperwork in with the module.
    Cheers.
    #236599
    timdowning wrote:Is there programming to be done on this module as I haven’t got any other paperwork in with the module.
    No programming required as far as I’m aware, just a one for one swap. But you’ll need to configure the salt setting once its installed. (IIRC is defaults to setting 0 – I think? 😕 )
    #236600
    timdowning
    Cheers Martin.
    Did want to goose the new board. 😉
    How about this bit;
    Cheers
