Bosch module 489607
  • #34266
    winker
    anyone got a copy of the coding instructions they can mail me
    cheers steve
    #241902
    gegsy
    Re: Bosch module 489607
    You can’t code a module unless you know what machine it goes in 😉
    winker
    model Bosch SGS43A18 GB27
    cheers steve
    #241904
    gegsy
    You have mail Steve 😉
    Simon46
    😆 Sicasym 😆
    S.
    #241906
    gegsy
    Simon46 wrote:😆 Sicasym 😆
    Lowest form of wit :duck: 😆
    timdowning
    Clarification please;
    Bosch SGS5362gb/01 FD8108400711
    I have got to change the module on this machine. Bosch have included the instruction sheet.
    As my machine is a /01 does this mean I have to carry out the wiring change? (They say appliances up to KI12)
    If Yes is the change to cut wire number 5 and splice it directly to wire number 7?
    Also, is ‘HS’ the on/off switch?
    Thankyou in advance.
    #241908
    timdowning wrote:As my machine is a /01 does this mean I have to carry out the wiring change? (They say appliances up to KI12)
    Yes you do have to carry out this wiring mod as your machine is before KI12 as it is KI01. Don’t forget also to configure the module as per the Instruction Sheet once you’ve done that.
    #241909
    timdowning
    Just remembered. 😉
    Module fitted and configured. All running well.
    (Module required due to no power to heater).
    #241910
    timdowning
    Spoke too soon….
    (Bosch SGS5362gb/01 FD8108400711)
    When I left this machine I tested it on a quick wash. Since then the customer has only used the auto programme.
    The customer is saying the machine will now only let her select the auto programme.
    I have just asked her to unplug and plug back in the machine. She can now select all programmes except intensive.
    I carried out the wiring change and set up ‘no sicasym’ zero on display.
    No other config details were in with the module. should there have been?
    cheers.
    #241911
    gegsy
    Yes, there should have been a coding sheet.
    Will send one over for you Tim 😉
    timdowning
    Cheers Greg.
    Having read various posts before ordering the module. I asked the spares dpt at bosch about config details and they said all necessary info will be in the box. First time I’ve changed one of these modules so had to trust what they said. 🙁
    Anyway rant over. 🙂
